metho in the fuel tank to get rid of any water?
ryan101
whittlesea
vx ss
Hi, sorry if this is a silly post but im new to commodores i just got a s2 vx ss manual with 145000km on the clock.
i noticed when i went and first had a look at the car is was low on fuel, and when i pickd the car up it was low on fuel so im guessing they used to run it fairly low most of the time!
As you know if it is low on fuel on cold nights it would build up condensation in the tank! i was told metho will help the condensation burn if there is any in the tank? is it safe or should i not even worry? i have only had the car 2 weeks, love the car
DLFHUB666
GIT 'EERRR DONE!!!
39
Nhulunbuy NT
VX SS, PX Ford Ranger XLS Dual cab
i know the oldman does this in his boat dont see why it wouldnt work in the car.
ryan101
whittlesea
vx ss
does it feel any different afta you put it in?
2DIE
ONEDOLLAHOLLA
South Aus
www.torn.com
97 Acclaim
I used to do this after my old HR was sitting for long periods of time, never hurt it but that was a old motor.
oska
vx custom 600RR
it's perfectly safe
the theory behind it is that water wont mix with petrol but will with metho and that metho will mix with petrol
soop
Banned
Smithton, Tasmania.
2003 SS Commodore Series II
Metho displaces the water, or absorbs it.
It doesn't really mix with the fuel but it will burn, unlike water.
pablo
Donating member
Was a 1997 vt v6 wagon
The tank wont rust!....... The fuel filter will catch any water droplets that get that far, so change the filter, then cut open the old one, then any water in the system will be evident. That'l put your mind to rest, ..........................to rest before you come up with something else to worry about...LOL
Metho in the tank is an old bushys trick, to get rid of moisture in fuel thats pumped from outback suppliers dubious tanks.
Cheap6
VP Exec
I don't think that you should even worry. If it's really a concern to you simply run a few tanks of E10 through it and change the fuel filter. "Metho" is just denatured ethanol anyway and I'm not sure that all the water is removed from it (unlike the ethanol used in E10).
