  1. ab56452001
    ab56452001 Member
    vn vacationer auto v6 sedan
    hi,now and again ( almost only happens when the motor is cold ) my car wont start, the raa man came and gave the electrical wiring socket that goes in to the coil pack a twist and away i went ! , looked at the connection and it looks and feels tight, the bolt is done up,so any ideas to what it could be ?, thanks in advance .........
  2. iRiot
    iRiot Merc with a Mouth
    Red Cliffs
    1994 Holden VR Caprice V8 HSV Enhanced
    its a dfi a you can change it with a new one
  3. ab56452001
    ab56452001 Member
    Thanks for reply,i gotta coilpack setup from a vp that was running o'k', hope its not to hard to use/swa, maybe its only the connection !,...........
  4. ab56452001
    ab56452001 Member
    Its strange just drove 2000km no probls only in the morning once !, gave it a twist an of i went !.........
  5. immortality
    Sth Auck, NZ
    pull the plug off and check for loose pins, get some electrical contact cleaner and go for gold also
