wobbles123
- Jan 18, 2018
- 171
- 78
- 28
- Location
- nsw
- 2008 VE SV6 Auto Ute, 2013 VF SV6 Auto Sedan.
Did you know that the VF series of Commodore uses a MICRO 3 FUSE. DUAL CIRCUIT BLADE FUSE in most of their fuse boxes.....replacing the the 2 bladed fuse in certain circumstances ....used in earlier commodores.
The middle blade supplies the current and protects 2 out going circuits.....if one circuit blows the fuse can be rotated if needed to power the fused circuit...in an emergency.
Take care that these fuses are examined carefully and are not causing an intermittent to another circuit when one side is blown causing all sorts of electrical problems....eg. lights, starting, battery, power steering, radio, fault codes. etc. etc.
