Microtech LT10 ECU Help.
Gallego
52
Ormond Victoria
VH SLE
Hi ,I had a fully built fresh RB30 Turbo in my VL Turbo,and Dyno tuner crack the block in 7 places ,It was only meant to be a run in tune.and it’s not admitting that it was his fault ,I’m running a Microtech LT10 Ecu,Can I get it data logged to see the maps and see what the clown did?
_R_J_K_
Zenki S14
Which 7 places and what was the exact damage? You should just be able to power it up and see if you can pull data from it depending on how its software is licensed and if it was actually set to log data.
I would try and look for more evidence before trying to blame the tuner first as there's a lot of custom components in the mix here. Could have leaned out and detonated because of a wiring loom short, or an injector could have failed, or the turbo could have overboosted etc...
