Mini Ice Age coming?
Hunter SS
Growing Old Disgracefully
Upper Hunter Valley NSW
2006 VE SS
Anne Minard
for National Geographic News
May 4, 2009
A prolonged lull in solar activity has astrophysicists glued to their telescopes waiting to see what the sun will do next—and how Earth's climate might respond. The sun is the least active it's been in decades and the dimmest in a hundred years. The lull is causing some scientists to recall the Little Ice Age, an unusual cold spell in Europe and North America, which lasted from about 1300 to 1850.
The coldest period of the Little Ice Age, between 1645 and 1715, has been linked to a deep dip in solar storms known as the Maunder Minimum.
During that time, access to Greenland was largely cut off by ice, and canals in Holland routinely froze solid. Glaciers in the Alps engulfed whole villages, and sea ice increased so much that no open water flowed around Iceland in the year 1695.
But researchers are on guard against their concerns about a new cold snap being misinterpreted.
"[Global warming] skeptics tend to leap forward," said Mike Lockwood, a solar terrestrial physicist at the University of Southampton in the U.K. (Get the facts about global warming.)
He and other researchers are therefore engaged in what they call "preemptive denial" of a solar minimum leading to global cooling.
Even if the current solar lull is the beginning of a prolonged quiet, the scientists say, the star's effects on climate will pale in contrast with the influence of human-made greenhouse gases such as carbon dioxide (CO2). "I think you have to bear in mind that the CO2 is a good 50 to 60 percent higher than normal, whereas the decline in solar output is a few hundredths of one percent down," Lockwood said. "I think that helps keep
Local Cooling For hundreds of years scientists have used the number of observable sunspots to trace the sun's roughly 11-year cycles of activity.
Sunspots, which can be visible without a telescope, are dark regions that indicate intense magnetic activity on the sun's surface. Such solar storms send bursts of charged particles hurtling toward Earth that can spark auroras, disrupt satellites, and even knock out electrical grids.
In the current cycle, 2008 was supposed to have been the low point, and this year the sunspot numbers should have begun to climb.
But of the first 90 days of 2009, 78 have been sunspot free. Researchers also say the sun is the dimmest it's been in a hundred years.
The Maunder Minimum corresponded to a profound lull in sunspots—astronomers at the time recorded just 50 in a 30-year period.
If the sun again sinks into a similar depression, at least one preliminary model has suggested that cool spots could crop up in regions of Europe, the United States, and Siberia.
During the previous event, though, many parts of the world were not affected at all, said Jeffrey Hall, an astronomer and associate director at Lowell Observatory in Flagstaff, Arizona.
"Even a grand minimum like that was not having a global effect," he said.
Wild Cards and Uncertainties
Changes in the sun's activity can affect Earth in other ways, too.
For example, ultraviolet (UV) light from the sun is not bottoming out the same way it did during the past few visual minima.
"The visible light doesn't vary that much, but UV varies 20 percent, [and] x-rays can vary by a factor of ten," Hall said. "What we don't understand so well is the impact of that differing spectral irradiance."
Solar UV light, for example, affects mostly the upper layers of Earth's atmosphere, where the effects are not as noticeable to humans. But some researchers suspect those effects could trickle down into the lower layers, where weather happens.
In general, recent research has been building a case that the sun has a slightly bigger influence on Earth's climate than most theories have predicted.
Atmospheric wild cards, such as UV radiation, could be part of the explanation, said the University of Southampton's Lockwood.
In the meantime, he and other experts caution against relying on future solar lulls to help mitigate global warming.
"There are many uncertainties," said Jose Abreu, a doctoral candidate at the Swiss government's research institute Eawag. "We don't know the sensitivity of the climate to changes in solar intensity. In my opinion, I wouldn't play with things I don't know."
Pretty heavy stuff!! time to go buy a few more trackie tops and beanies!!
doms3
Banned
Vz
Good i ****ing hate the hot
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
Thats what you get for banning CFC's... Bring back the Global warming theories, it was something to look forward to atleast, the cold weather sucks.
minux
Infidel Bear
Thank god commsirac isnt here anymore, we would be getting a lecture on how these scientists are paid by the oil companies etc.
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
LOL.... That was my frist throught when reading the title.
Hunter SS
2006 VE SS
i saw it on a Kawasaki forum i visit and thought it was a refreshing difference to the global warming crapola
Scooter79
41
South Coast, NSW
VSII Calais supercharged
badaz
47
Supercharged VX S
Its already nice and cold here in Canberra but as Scooter79 said the L67 loves it.
