Qmyster101
- Sep 11, 2016
- 11
- 1
- 3
- Age
- 50
- Location
- sydney
- VE Commodore
Hello,
Was driving recently and vehicle suddenly started Misfiring and started giving me a Stability Ctrl Fault on the Dash (Later i also got a ABS and Brake Warning. I have been at it for a week trying to Diagnose the issue with no Fix....What ive done:
* Pulled Fault Codes - PO306 Cylinder 6 Misfire
* Ohm Tested the Ignition leads (Which are good)
* Swapped the coil to check if it was the problem (it wasnt)
* Checked all the Spark Plugs (Changed earlier this year and looked fine)
* Removed the Driver's Side Cat and it also looked good (Still need to get it tested)
* Changed Battery.
My suspicions are there is a slight warp in the front discs and whilst braking it has tripped a wheel sensor but would that cause an engine Misfire?.... im not getting any codes relating to a Wheel sensor issue. Any help would be most appreciated.
* Changed Battery.
