Misfiring VZ 6
Diggertpi
67
Lancefield
VU
I have a VZ 6 with 200k on the clock. After hard acceleration (passing a truck for example) the engine misfires until such time as I stop the car and restart the engine. This has happened a dozen times or so over the last few months. Any ideas? TIA
Benboy
Hill River, SA
2007 SVZ Wagon
What's the service history ? Have the plugs been replaced in accordance with manufacturers recommendations ? Perhaps something you can do is to carefully check that exposed electrical leads are obviously connected. You could also get a bottle or two of Fuel System Cleaner, I use Moly from Supercheap. https://www.liqui-moly.com.au/products/fuel-system-cleaner-conditioner/ Good luck
Fu Manchu
WA.
Sounds like a faulty coil.
Diggertpi
67
Lancefield
VU
Thanks one and all. Coil seems to be the consensus - probably due for plugs also.
DIgger
Fu Manchu
WA.
Check out MACE (who are a forum sponsor) They do plug and coil packages. Do all at once.
Fu Manchu
WA.
Make sure you gap the plugs before installing them. They should be pretty good but best to check.
