miss/flat spot under load.
Wombles
Cars cost too much.
Seems im getting a miss/flat spot under load when accelorating. Sometimes it even backfires in the engine bay.
Could it be a coil on the way out or DFI?
Doesnt do it when in park.
Wozza
VR_GS commodore
yeah and leads braking down....is another common cause
Wombles
Cars cost too much.
Good point Wozza.
Tomorrow ill pick up plugs and leads.
Think they're like 2 years old. Maybe 3.
Immortality
Staff member
Sth Auck, NZ
I had the problem with the missus car, hers was leads but not before replacing everything bar the CAS and multiple sets of leads. I have the OEM Bosch type leads now and no more problems.
Wombles
Cars cost too much.
It just so happens this arose after I did the o-rings..
Only happens when warm it seems.
Brett_jjj
Tamworth NSW
vs commodore
Ive seen faulty ignition coils cause very similar problems..
Wombles
Cars cost too much.
Update on this: Changed leads and plugs. Think they're 50k old...
Number 1 cylinder, first one tackled, after pulling off the lead off the coil, the rest came with. Ended up being a 3 piece lead.
Wombles
Cars cost too much.
Better. But I think I still felt a miss/backfire.
Immortality
Staff member
Sth Auck, NZ
Then I would consider looking at the coils.
I would also run some injector cleaner and maybe change the fuel filter if it hasn't been done in a while.
