So far I have cut the neck off. I will be welding an adapter plate and bolting a hand made fibre glass 90°neck mated to a 90mm tb.
I am thinking of placing a divider plate through the neck to split air to each bank. Upon cutting the neck I noticed the runners at the plenum are rough some have quite a bit of residual slag. Im contemplating cutting off the base plate and cleaning and porting the runner inlets.
Has anyone modified the bananas and if so any help, advice, heads up.
Cheers.
Cheers.
