gday, I'v herd that with auto trannys if you mod the engine (exhaust system, peformance lead plugs ext nothing too crazy) i would need to re program the transmition? is this true, Also I plan to lower my car on SSL's would i need to re rool the guards and buy a camber kit? any help would be good
those parts having nothing to do with the transmission and will not alter anything... cant help with the camber kit
thanks, yeah i know they have nothing to do with the transmission but aparenly mods alter the shift points around
Those mods and any other performance mods like that wont effect your shift points.The TPS will effect your shift points and also the speed sensor on the gearbox (auto).And finally the valvebody will control the shift points.Changing plugs leads fuel filter exhaust,supercharger or anything like that will only try to help you get there faster but to alter your shift points your would have to modify the valve body/T5 solenoid,TPS adjustment,and also the computer for the auto if present in that model.
oh ok thanks. I'v got a few question that ill chuck in this thread so any help would be great. I would like to lower my car on ssl or sl king springs what else is involved in doing it proply iv herd you need new shorter shock absorbers? is this right? once again any help would be good
id get the camber kit, because the wheels tend to go to strange angles... from what iv been told and seen. Iv got the family pack calais suspension so i have no experience, but id love to lower it, i get soooooo much roll
