My fuel guage was not working either. Hasn't worked properly for over a year. Got around to replacing the fuel pump & sender. Bumper, tow bar setup off, to be able to remove the tank.
The hose from the fuel filler to carbon canister was also replaced. There was a couple long slashs in the hose.
Moved the reversing camera under the tailgate handle. It used to be in the bumper above tow bar. Looks a lot tidier now.
The return spring in the ignition switch has broken. I have a spare one, just got to get around to fitting it.
I have a trailer plug(s) flat 7 pin l'm trying to fit. Not enough room. Have to work out something else, or a smaller plug (if you can buy one that is smaller).
I have that system. I was going to use that system (hang the flat wiring through the tailgate), but the wiring would be rubbing on the freshly painted bumper, which has put me of that idea.They do make flat towbar wiring that stays inside the car and when you're ready to use it, it's thin enough that it can be hung out the tailgate/bootlid, with it being shut and not crush it....I just can't remember all the cars that have it fitted....EF era Foulcans seem to ring a bell as one....However if you have a bit of spare time, having a sticky around a wrecking yard might turn one up
The plug itself is rectangular, rather than the older round style.....That being said, you can also get adaptors that go from the rectangular to round style plug....So might be worthwhile looking into....
Thanks for your coments vc. Much appreciated.Just had a sticky at how the loom runs with my VY....
They have a hole drilled in the wheel well, directly behind the bumper bar....From there the loom runs inbetween the bumper bar and the rear panel...The plug is fitted to a bracket that is welded off the side of the towbar....
Unfortunately I can't supply pictures, so hopefully the description is clear enough for you...
