losh1971
- Jan 17, 2010
- 22,628
- 22,433
- 113
- Location
- North Tas
- VE Series I SS Ute
So the short is I had a blocked drain that I cleared because it was spilling water on the drivers side through the control levers and up even higher. All good got under and drained the box, chocka with water. Now heater works fairly decent but there is one exception once I put the aircond on at the same time there air out the vents gets barley lukewarm. Switch the aircond switch off and after 2-3 mins air is blowing quite warm but the windows fog up. Is this just the way VR's are or is there something I can do to use both air and heater at the same time? Or is this still related to partially blocked core?? Core has been chemical and reverse flushed a few months ago.
