more power from rb30
VLMAN86
VL EXECUTIVE
hey guys can anyone tell me some cheap easy ways to get more power out of my stock vl rb30 help
Dylan VT
Metal forever
33
Port Macquarie
VT commodore acclaim
Well I don't know much about this type of stuff but I guess you could get some pacemaker extractors. Not exactly sure on cost though but I think over 400.
In combination with a good exhaust system that should give you a few more kW. You should get a good exhaust and good extractors fitted for just under $1000.
Sabby
MSABBY
melbs
VU SS FIFTY
yep a agree.
extracters give you 10% more power, as ive heard from people.
VL Berlina 5speed
Apprentice Panel Pusher
Project VL Show car, VS Exec, VY Ute, YZ250F
Common things that are done for NA vls
  • extractors, high flow cat, cat back system
  • CAI if wanting to cut a hole
  • K&N filter for CAI
  • bigger leads
  • advance timing
  • XF falcon throttle
then you can turbo, supercharge or open it up and place like cam, head work and other stuff
just depends on budget
just remba with power you need stoping power, and the abilty to place it down to the floor so dont over look suspension and brakes as they are just as important if not more then going quicker
VLMAN86
VL EXECUTIVE
Yeh Ive Got A 2 And A Half Inch Exhaust Exhaust From The Cat Back Already
bangers
42
NSW
EL FALCON XR6
don't put a pod in. they suck more hot air then cold.
bangers
42
NSW
EL FALCON XR6
where would you put the pod? the only place is in the wheel arch and they get covered in sh#t. just use a k&n panel filter in the original air box and run tubing somewhere. or put a hole in the bottom of the box through to the wheel arch.
1991_Vn2nV
34
Gumeracha, Adelaide Hills
91 VN Berlina & 03 VY Berlina
You put the pod where the air box is... Its not hard to make your own box to house the pod, and run a custom CAI through to the POD.
This is what I did to my VL, and the next stage was going to be to replace the standard box with my own housing a POD:
