85berlina
- Jun 27, 2006
- 137
- 3
- 0
- Location
- Sydney
- VK berlina sedan 202
Hey Guys,
I have a VK with a stock carby 202 and a trimatic behind it.
It drives pretty good, but when you plant it, it will go fine until it goes to shift into second. When it goes to shift into second, the engine will flare like as if the transmission was in neutral and power isn't being passed through and you will have to play with the accelarator a bit to make it shift.
It is also a bit clunky with the automatic downshift at higher speeds.
This was reconditioned by the previous owner 4 years ago and my brothers HX with a stock 202 and trimatic doesn't do this. He has the original trimatic and it is perfect.
BTW, I did a service that included changing the fluid, filter and gasket, pan gasket and servo cover gasket. I didn't adjust the bands because I didn't have a torque wrench. Could we be looking at bands that require adjustment, or something else.
An ideas?
Thanks guys
An ideas?
Thanks guys
