Motor hard to turn over
fastvs
VY II SS
Hey guys I have a problem with my car, I cracked the timing cover and replaced this now the motor seems to struggle to turn over even by hand. It does turn but not easily, starter turns it over maybe twice before giving up? Is it possible to have done harmonic balancer up to tight so its hitting timing case? I havnt touched anything else since last drive
Any help would be great
Michael
fastvs
VY II SS
btw this is my daily vs v6 not the ss
The1
A Memcal a Day Keeps..
QLD
www.eyeit.org
VS V6 Berlina Auto
nar can't do the ballancer up to tight, sounds like somethings not right, unfortunatly you might have to go back and check everthing, was everything in order before you put the cover back on? How'd the old timing cover crack or where?
RX25SE
Real cars are steel cars.
MY07 Liberty 30R Spec B 6sp wagon
Remove balancer and turn it over.
If its still tight, pull the next bit off.
And so on, and see if it frees up.
fastvs
VY II SS
Ok have pulled balancer off cranked did same thing, pulled spark plugs out reduce compression motor turns over fine plugs in = very hard to turn over
Brett_jjj
Tamworth NSW
vs commodore
It might just be a weak or half flat battery.Turn the headlights on to high beam, and try to start it,do the headlights go dim or go out completely,try it and see what it does and let us know..You could try using jumper leads and another battery connected up with yours.Take note of how good it winds over then.
soop
Banned
Smithton, Tasmania.
2003 SS Commodore Series II
I agree with brett. Sounds like the battery.
Check its done up right and that the strap to the starter is good.
fastvs
VY II SS
When I jump it it starts :) I have come to the conclusion my alternator isnt to good as soon as I take jumper leads off car dies almost right away
