Motorsport rear lip spoiler removal
lockwood
77
canberra
VF MSE
I'm thinking of replacing the small rear lip spoiler on my Motorsport with a larger one in a similar style. Does anyone know how the current one is fitted, stuck on? if it is, how to remove it without damage to the paint?
GMVPSS
VFII Redline Wagon, 7sec Pontiac GXP, VY Ute
I have read here there are holes with bolts holding it down.
If I was you I would buy a second bootlid, build it up the same as the first, except with the wing on it and swap them over monthly at will. :)
Ron Burgundy
NSW
VF II SS
Slightly larger one as fitted to SS should bolt on...
Anthony121
VF SSV Redline MY17 & VF Director
The small spoiler is stuck on with double sided tape.
lockwood
77
canberra
VF MSE
Do you know how to remove it without damaging the paint? I don’t want to get to a point where I am damaging the paint and have to continue regardless.
Anthony121
Heat it up and gently pull it up.
duaned
52
Newcastle NSW
M6 Red Hot MSE
Correct. I removed my little stick on spoiler no issue. I used a hair dryer, fishing line, lots of eucalyptus oil and paitence, plenty of it!
MY17DIR
44
Gods Country, NSW
MY17 LE Director....
What sort of spoiler are you thinking of replacing it with?
lockwood
77
canberra
VF MSE
a similar style, just a bit larger. I think it would be like the one on the SS
Ron Burgundy
NSW
VF II SS
For SS one you would have to drill holes etc to mount it correctly. Why bother ?
