MSD coild pcak and DFI or super spark or genuine?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jas98, Jun 11, 2011.
  1. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    is it worth putting MSD coils and dfi on my vs commodore? V6?
    like would i benifit from it? i want to replace my coil pack for good measurs
    also i found this one on ebay has anyone ever herd of it?
    YELLOW JACKETS COIL PACKS HOLDEN COMMODORE 3.8L V6 -NEW | eBay
    they say a possible power increase of around 11KW at the wheels but im not sure if upgradeing spark would achieve that?
    thanks
  2. Kunu
    Kunu chasing the big 300!!!
    97VT SSsuper6(179rwkw),daily barina,2008 VE Clubby
    lol 11kw at the rears i find that hard to believe,i have MSD coils on my Vt and rate them pretty good..in saying that normal ones are ok!!
    you can get MSD coils and iridium spark plugs for like $250 which is excellent value :)
    these are pretty good:
    MSD Coil Kit 8224 : Commodore V6 - VN VP VR VS VT VX VY | eBay
  3. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    I know that theres definitely a noticable difference between the genuine holden coils and some of the cheaper aftermarket coils.With the genuine ones the car starts better and just generally runs better..Ive tried both sets,both brand new sets, and thats how I came to the above conclusion about the cheapo coils compared to the genuine coils...Id like to see if theres any difference between the red MSD performance type coils shown in the link in the above post,the yellow coils in the link back up in the first post,and the genuine holden coils.I noticed that the yellow coils are made by GE and BASF.I reckon the'd probably be as good as MSD brand..
  4. RIDE:42
    RIDE:42 crew chief
    vuss
    Save your $ standard ones work fine even under forced induction
  5. RIDE:42
    RIDE:42 crew chief
    vuss
    As for plugs i use NGK tr6 $3 each on TTls1 they work better than any tried
  6. VZ57SSZ
    VZ57SSZ Member
    Central Coast
    MY16 VF Series II SSV
    Plugs don't make a huge difference, I have the Bosch Platinum Ir-Fusion, defiantly is smoother and more responsive but not worth $140 for 6 I got them for $59 delivered from US part number 4504 (L36/Ecotec V6)
  7. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Aftermarket coils are not worth it. From memory Super 6 coils are better. For plugs the standard ones Holden use outperform the rare metal types.
  8. greenacc
    greenacc Searching for the billion
    VE Berlina
    I have to say, when it comes to the ignition system on Ecotecs - Don't #### with things that are working fine. !! As soon as I replaced the first coil on mine i had problems for ever after.
    What i would recommend you do if you've still got all original coils, DFI etc is go buy a spare DFI and set of coil packs from a wrecker and store them safely in the boot. One day you will need them, you just don't know when or which part you will need.
  9. TI3VOM
    TI3VOM Active Member
    Here there and everywhere.
    VT Commodore
    The eBay MSD coils that have been mentioned are a lot cheaper than the standard Holden Bosch ones!! I was quoted $175ea for the standard ones so how does that save you money?
