Mulitmeter help
WogBoyz
435rkw/590rwhp
Cairns, Qld
08 VE SSV M6 Ute
just wonder ppl
i bought a mulimeter exactly same as this one
now im wanting to test my battery for the amout of volts or whatever it is at cold starts ive been told it shud be around 14 when engine off, and around 13 when running
now i have no idea how to use this thing haha what do i set it on to test it?
cheers people
33
Cairns, QLD
VS S Pack Ute
Turn the dial to the 20 near where it is presently pointing to in that pic
Put the red lead on the (+) terminal of the battery and the black lead on the (-) terminal.
Should be 12-13 when stopped and 13+ when running I think.
hako
Donating Member
78
Toowoomba SE QLD
VS11 BT1 V6
A cold battery or one that has sat overnight should read a minimum of 12.6 volts engine stopped and when the engine has been running for a fair while and things are nice and warm it should read a maximum of 14.2 volts engine running. Have fun.
hako
Donating Member
78
Toowoomba SE QLD
VS11 BT1 V6
Cursed CX8
Banned
Walking distance to FG meets
VY Adventra
just make sure the current doesnt blow the **** out of that little multi meter.
Locky_MAC
VT SS 5.0
You will have to change the RED plug that goes into the multimeter to the DC Voltage or you will get nothing?
Are you testing something or just having a look?
Voltages will stay around the same hot or cold, 12V something when engine off and 14V something when engine on if your alternator is working?
If you want to truely test your battery, start your engine while reading the voltage it should stay steady at around 9V.
Have fun.
