Helmo645
Multicolour Footwell LED Install
Things Needed:
RGB LED Strip (Simply type rgb led straight into ebay and buy as much as you think necessary, can cut it every 10cm so if got 1 m could seperate potentially into 10 10cm portions or 2x50cm etc..)
Music Infrared Remote Controller (Again type this directly into ebay, should be a box type item with speaker grill looking bit and a remote included)
Various colours and lengths of cable (Just get from Jaycar or wherever..)
Soldering iron + Solder
What to do:
1. Suss out placements of your LED strips and then measure up how much you need for them.
2. Cut along the very apparent line thats every 10cm or so at the desired amount of strip you want..
3. Scrape back the plastic around where you cut (again shows where to do as there is a image over the top of it), you will now see 4 terminals which should have also said what all terminals were for (+ive, red, green or blue). Solder on appropriate coloured wires to appropriate terminals)
4. Do this process for as many led strips as you want.
5. Mount controller box somewhere that the remote will be able to work with it easily, I simply screwed mine up top of the footwell.
6. Run the cables you just made from the LED strips into the appropriately labled connections of the controler.
7. Simply run a cable from the + of the controller to any positive cable in the car, simply splice in or if you want run through firewall to positive of battery, ground the negative part to some steel in the footwell..
8. Test.. who knows you may have soldered colours up wrong and in one footwell have blue while the other has red.
9. Enjoy your new footwells that you can change colours instantly or get to strobe with the music, fade etc
Will be updated with pics when I take some
Things Needed:
What to do:
