speco
- Aug 9, 2009
- 51
- 0
- 0
- Location
- coalville, vic
- VS v8 manual Calais, Ve ute, 68 Hk Holden v8
my 1968 hk holden v8 308ci 4 speed manual,
iv rebuilt this car from the ground up! cost me $17,000 did all the work myself no1 helped in anyway
specs
vh blue v8, 286 cam, flat top pistons, die ground block, 9.5 comp,my own custon port and polished heads, match ported, torquer single plane manifold, full balanced, 7kg flywheel, 1250kg clutch, 650cfm 4150 (4777s) carby d/pumper, 1 inch carb spacer, rollmaster timing chain, 50,000volt hEI ignition, extractors, made 194rwkw
aussie 4 speed manual, iv machined it and inststalled biger main brgs, machined out the old cluster gear to accept caged needle roller bearings
salsibry 10 bolt diff lsd 3.36 gears
taken a little over year of hard work but im happy
thanks for looking
