My 2000 Vt Calais missing when under load.
Nigel07
Gold coast
Vt Calais supercharged
my 2000 Vt Calais runs fine for about 20min when cold then when under load it starts missing. Have put new leads and plugs and still doing it... also just noticed when In park and rev engine to around 4000-5000 rpm the traction control off and low traction light flash and makes a beeping sound.. what would cause these problems. thanks....
krusing
Melbourne, Bayside
Have you extracted any codes out of it ?
If not, I recon that would be your best option as a starting point.
Does sound like a Vacuum leak, as the Super6's have a few vacuum hoses than the standard L36's.
Nigel07
Gold coast
Haven’t done codes as no engine light on. Is it worth checking anyway.. I will check vacuum hoses 2day.. thanks
greenacc
Searching for the billion
VE Berlina
Check anyway not all codes switch the engine light on.
oska
vx custom 600RR
if you're trying to rev it before it reaches operating temp, the rev limiter @4500 kicks in
Nic's VT
Christchurch
VT Calais Supercharged
Mine was doing this so I replaced the coils as well as plugs and leads. Hasn't done it under load since. I do now have a miss at idle however.
Nigel07
Gold coast
Finally found the problem.. Needed new dfi module and replaced coils as well. Runs like a dream now..
