The VR/VS 424 ecu has the thermo fan...the VN/VP/VG/VQ 808 only has a/c thermo fan switched from a/c fan relay so you need to wire up thermo through a davies craig controller
The haltech platinum sport gm is plug n play, a bit expensive $$, plus you need extra adapter for 2 O2 sensors for twin separate exhaust
You said you did a conversion on your car, so I take it was a 6 cyl before ? So what model did you get motor/trans from ?
Hey Achoo, that's a bummer i thought the VN ECU was capable of switching engine fan, didn't realize that was only a VR VS thing .. I'm not using the air conditioning anyway so if I can make use of that circuit that will do? .. car was built from a smashed 1990 vn bt1 auto that that i bought complete for the running gear in about 2003 /2004
