hey guys heres my vn hope u like engine, buick 3800 Raptor V super charger running 12psi, Big FMIC, stainless steel polished plumbing, ported and polished heads, crack tested, acid dipped and bead blasted, pressure tested, 1.8 ratio roller rockers from yella terra, machined valves, ported oversize valve seats, comp cam springs and retainers, comp cam collets, honed cylinders, forged pushrods, surecam custom cam billet cam grind with roller profile, power bond race grade harmonic balancer, roll master double row timing chain(removed balance shaft, roller lifters, msd blaster coils, split fire 8.8mm dual core leads, iridium split fire plugs, 70mm throttle body, air restrictor removed, custom chip from chiptourque ,Upgraded internal pump, running a bosch 044, 36LB injectors,SARD rising rate fuel reg, Custom stage two shift kitted T700 gearbox with corvette servo, Z pack clutches, (the beast) reaction shell, 3000rpm stall, ,VT twin piston calipers and disks, S pack twin diaphram master cylinder with 1 inch bore, 3.89 diff, with lsd hemisphere Exhaust: HM headers into 3inch mandrel bent system, Suspension: king springs and koni shocks heavy duty, oversize adjustable panhard rod, oversize front sway bar, Wheels: 19 inch star corp deep dish chromies, now after some 20's Modifications: fully retimed interior, plastics, custom made s pack dash with blue LED’s, VX Clubby front bar and skirts, VT Clubby rear bar, not the cheap ****ty ones either, Nissan 350Z Blue with house of colour 3 layer white ice pearl, rocker covers are the same colour, Stereo Audio / Visual: pioneer DVD head unit, Kevlar core splits front, 3way 6inch pioneer rears, Kenwood 4inch splits in boot, alpine amps in boot with 2- 15inch mtx subs built in custom and re trimmed enclosure, will soon be done in fiberglass and painted the same as the car Estimated Power: untested future mods: bottom end rebuild, unsure of compression though, needs 3.5” intake piping, raptor is looking at the new intake manifolds defiantly the first buyer here, and in the next couple of weeks going to run 16psi, then a 75 shot of NOS..
i like the engine bay mate and that you are doing up the ol buick. Now each to their own opinion but i think the interior looks like a McDonald's playground... that's just my 2c
Lachie, you silly boy, yours is a calais. So whatever result he gets on the dyno, you'll have to add about 50rwkw me thinks. Calais POWAA.
