My brakes suck!
Discussion in 'VY Holden Commodore (2002 - 2004)' started by SS-REX, Jan 21, 2014.
  1. SS-REX
    SS-REX New Member
    THE GC-QLD
    03-VY-SS-UTE
    Well yeah they do time for an upgrade i reckon what are your recommendations?.It's an 03 VY SS Ute manual maybe a pad/rotor/fluid combo or even a caliper upgrade depending on price.I do a lot of heavy traffic driving get to a highway once and a while like to start dragging it at test and tune days to muck around like to stop at the end of the strip too. Any input/info would be great thanks :)
  2. kingyinperth
    kingyinperth New Member
    safety bay
    VE 2012 Heron SS Thunder Ute M6
    Caliper upgrades aren't cheap,how much grunt you wishing to pull up well? I don't know the standard rotor size for a VY V8 f & r or if you can upsize to VE spec(for example) But there would be info on that around if you do a search and or wait for feedback from a VY V8 owner.
    quality slotted rotors/pads/fluid would set you back less than a grand dependent on the actual spec you chose,even if you upgrade to VE 321 front/324 rear combo(plus fitting if you don't dyi)...
  3. Towcar
    Towcar Well-Known Member
    Auckland NZ
    VX Berlina Wagon
    could look for second hand Harrop HSV set up, there is one in NZ on trade me for around $1500 excluding rear discs and pads.
    My plan is to go with Bendix Ultimate pads all round and slotted discs change the fluid to a higher performance non-silicon based and see if it improves as much as my FTO did.
  4. VRStato64
    VRStato64 Member
    Eastern Suburbs
    VY SS II 6 speed
    Im about todo my brakes I have the parts doing then next week.
    A few options I found in my research.
    What im doing is good dba rotors all round. Dba t2's $100 a corner, then really good pads cant remember which ones but about 70 a pair. Cheapest option and very decent.
    Second hand hsv set 800-1400 but chances are the rotors and pads will be worn and n3ed replacement either straight away or in the near future. Which means your looking at another 600.
    Sent from my GT-N7105 using Tapatalk
  5. kingyinperth
    safety bay
    Anyone know anything about this mob below??..prices are on the cheap side which is of some concern,warranty etc the same as competitors so they say...
    Holden Rotors // RapidRS.com.au
    Can the OP go bigger discs without modification??
  6. Big-Al
    Big-Al Banned
    Aussie and proud
    VY SS 5.7 M6
    no, larger discs require larger calipers.
    From memory the fronts are 315mm and the rear are 305?mm same as the V6. Yes that are ****. Get some AP racing or Harrops if you want to stop.
  7. VRStato64
    VRStato64 Member
    Eastern Suburbs
    VY SS II 6 speed
    The ve brake upgrade kit from gsl is about 800. Full brand new kit. Problem is that you can only use rda rotors pm gsl for details but a good option.
  8. Towcar
    Auckland NZ
    VX Berlina Wagon
    I am going to go out on a limb and say that you may be surprised at what good discs, pads and new good quality fluid will do for your car.
  9. commodore665
    commodore665 expat Saffa
    New Zealand via Cape Town
    2005 SV6 & Alfa Romeo 156 V6
    Just get them fully serviced , don't waste money on an upgrade .
    Sent from my iPhone using Tapatalk
  10. SS-REX
    SS-REX New Member
    THE GC-QLD
    03-VY-SS-UTE
    Yeah i would go for a Bendix Ultimate pad and a T3 rotor set with Motel Brake fluid you know the hi temp rating one normally. But thought I'd go with something a bit more than average for me. As i will be modifying my Ute with more power upgrades sorry i should have stated that in my original post.Would i be able to get 4pots with a bigger disc for under a grand?. I'd be happy with a bigger front set up and pad and rotor rear change for now. Thanks for the input so far guys..
  11. SS-REX
    SS-REX New Member
    THE GC-QLD
    03-VY-SS-UTE
    Is that just for the fronts?
  12. kingyinperth
    safety bay
    front and rear rotors,pads and fluid,not calipers...probably wouldn't get out of caliper change even one set for under a grand no,although I haven't priced calipers.
  13. PIR4TE
    PIR4TE Banned
    AWOL with Ari
    Black Pearl
    I have VE SS front / rear calipers, pins and HPX pads in Brisbane, $200
  14. TI3VOM
    TI3VOM Active Member
    Here there and everywhere.
    VT Commodore
    Keep an eye out on eBay & places like that. I got front only my AP Racing kit brand new for $1500, at the time they retailed for $3500.
    The difference that kit made was amazing!
  15. Towcar
    Auckland NZ
    VX Berlina Wagon
    I am not sure what the rules are where you are but it should be noted that changing brakes to non-OEM may mean you need to engineer/cert your car, in NZ you definitely do, here is is about $480 to get a cert done.
    That is why I am waiting on a set of Harrop's to come up as they can on the VX HSV so it can be argued that they are OEM.
  16. VRStato64
    VRStato64 Member
    Eastern Suburbs
    VY SS II 6 speed
    Nah its a full kit. Careful though cos they are not a direct swap. Which is why you have to buy from gsl as they have made a special kit and special rotors to suit. Check out the sponsors section they have a thread.
    And you could get a full set of big brakes for under a grand. Just wait for second hand hsv brakes, problem is they will be second hand and may need to replace rotors and discs at some point again.
  17. SS-REX
    SS-REX New Member
    THE GC-QLD
    03-VY-SS-UTE
    Thanks for the reply's guys sorry for the late reply.I was thinking i might wait for a second hand hsv set up to show up on flea bay but as VRStato64 stated i will end up having to replace the rotors down the line.
  18. lowandslow
    lowandslow Well-Known Member
    NSW
    V2 III Monaro
    I paid 650 for my 4 pot ap racing front setup incl rotors. Second hand. If you want to stop, spend the money on decent brakes and not half arsed bitsa kits. Search eBay forums Facebook like a hawk.
