My Car Whistles.....
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by DaPlaya, Jun 6, 2006.
  1. DaPlaya
    DaPlaya New Member
    97 VS Series II
    Hey Peeps.
    Did a search but didn't pull up much, I was wondering if any of you VS owners here have inherited a whistle in there car? at about 50 - 70 K's per hour my car develops an anoying whistle, it's not loud it's just noticable and anoying.
    It also seems to be only comming from the drivers side, while I've been driving i've checked Mirrors, windscreenwipers, windows. it's not the mirrors as I've had the window down and pulled the mirror towards me and away from me (spring loaded designed to withstand small nocks) and that's not it, it's not the wipers as i put them on and the whistle is still there, and it can't be the window cause it happens when it's down.
    any thoughts? anything else I should check. I was thinking the windscreen maybe:confused:
  2. Struma
    Struma Urge Surfer
    VS S2 Executive Ute
    Whistling in the dark
    My ute has a whistle as well - at least I think it is an air flow noise, it begins to kick in around 40 - 50 kmh.
    I can't localise mine either - was thinking it might be coming from one of the door/window mouldings.
    I also think it is more on the drivers side, but then so am I...
  3. Infus10n
    Infus10n New Member
    Holden Captiva (Work Demo)
    My guess would be door seals.... or a supercharger :p
  4. DaPlaya
    DaPlaya New Member
    97 VS Series II
    Oh yeah forgot it could be the SC lol.. but I don't have one :(
    door seals eh.. hmmm, i'll check it out, would make sense since the drivers door is generally used more than anyother, which creates more wear...
  5. fitzy2005
    fitzy2005 New Member
    Wide Bay, Queensland
    VY S2 Berlina
    whistle or whine? before gear change cood be dif/wheel bearing etc dunno
  6. clinster73
    clinster73 New Member
    VS Berlina S2
    I have a whistle too but its only while accelerating. I think it could be a loose vacuum pipe or something.
  7. DaPlaya
    DaPlaya New Member
    97 VS Series II
    definatly whistle, I've had my fair share of, diffs, wheel bearings, gearboxes, etc.
    it's faint but noticable and anoying. I'm sure it's wind whistle as when going below 40kph it's not there (not enough wind to whistle, try half heartedly whistling by just blowing air) and when over 70kph the wind is to strong so a whistle can't occur....
  8. ssute57l
    ssute57l New Member
    VYII SS UTE
    check mobile phone aerial.
  9. CRAIGO_VR
    CRAIGO_VR New Member
    Southern Adelaide
    VR Commodore 'S'
    try the glove box mate as when im driving and i open it up. you can hear the whistle louder!
  10. DaPlaya
    DaPlaya New Member
    97 VS Series II
    errr Mobile phone aerial? please enlighten me as to what you mean. I have no car kits, not mobile phone aerials outside the vehicle, my mobile phone hasn't even got an aerial, do you mean the cars aerial?
    that could be a point, I don't actually have an aerial, as it has snapped off, maybe the wind over the aerial whole could be creating a whistle.
    open the glove box. ok i'll see what I get
  11. VRAddiction
    VRAddiction its never fast enough
    Vy SS Manual Ute
    if you have installed a head unit sometimes if there not earthed properly they can develop a whistle
  12. DaPlaya
    DaPlaya New Member
    97 VS Series II
    No head unit installed, so that rules that out.
    although how would the head unit create a whistle, via wind or electronic interference
  13. andrewmac
    andrewmac Member
    S2 VE SS
    I would be looking at the window and door seals.
    My old Vk had a whistle and it was the back window had a bit of seal missing in the top back corner but that was only when i was on the freeway.
    Its worth looking over as it can drive you half mad sometimes if you drive at higher speeds alot.
    And the stereo whistle thing can happen its in bros car as he accelerates you get a nice little whistle sound but i dont think yours has that sounds different to me.It happens when a wire touches the body i think something like that but it is not really a wind sound.
  14. DaPlaya
    DaPlaya New Member
    97 VS Series II
    the whistle your explaining is an electronic interference and the whistle you hear comes from the speakers... usually happens when somthing isn't sheilded properly.
    ok I'll be looking at doors, seals, wholes, crannies, the lot.. I wish I had a wind tunnel :)
  15. ssute57l
    ssute57l New Member
    VYII SS UTE
    sometimes the mobile aerials coil (in the middle) can cause a whisle if you don't have don't worry.
  16. BrentAEI87Y
    BrentAEI87Y New Member
    VR Executive
    my vr makes a whistle to around 70 k's as well but its only wen i give it some acceleration then wen i have reached the speed i wont to go it stops
  17. =Calais v8=
    =Calais v8= Holden Tech Apprentice
    S/E Melbourne
    VSII 5.0L Calais, 13b ae71
    got a POD?
  18. DaPlaya
    DaPlaya New Member
    97 VS Series II
    nope no pod, it's definatly not engine noise, made sure of that, things i'm going to check this weekend are:
    Door seals
    Door outside trim pieces
    arial whole (even though it is on the passenger side)
    windsreen seals
    and anything else...
  19. UtelemO
    UtelemO New Member
    vrv8ute
    does it stop when you put your foot on the clutch? could be a thrust bearing.
  20. vh-holden
    vh-holden New Member
    darwin
    VS sedan and a VK DRGWGN
    the other way to fix it is to either get a louder exhaust or turn the stereo up. worked for 5 years in the vh keeping the wind noise down.
