P0327 - Knock Sensor Circuit Low Voltage P0332 - Knock Sensor 2 Circuit Low Input (Bank 2) P0523 - Engine Oil Pressure Sensor/Switch Circuit High Voltage P1626 - Theft Deterrent Fuel Enable Signal Not Received P000- no more stored codes, end of list. ------------------------------------------------------------ Well it all makes sense with the codes I got. P0327 and P0332 indicates faulty knock sensors, I am getting a little hesitiation/ loss of power. P0523 indicates oil pressure sensor bad, just need to replace it. P1626 means theft related, in simple terms my locks are screwed. That makes total sense because I am having problem with the damn locks. P000 the last code I got means no more stored codes.
i got the p0327 code too, did you fix yours? i ordered 2 knock sensors and a loom, apparently mice and rats chew through the loom effecting the sensors and can throw fault codes
