My diff is stuffed...help needed on IRS LSD
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by dakiwi, Nov 11, 2007.
  1. dakiwi
    dakiwi New Member
    VS SS V8
    Hi everyone,
    I am new to this forums, and forums in general.
    I have a VS SS V8 Series 2.
    I have owned it for 12 months, its a bloody awesome car.
    BUT, my diff is making TERRIBLE noises,
    mainly a whining noise at all speeds.
    It sounds really bad, but the diff itself seems to operate OK.
    This is maybe the crown and pinion???
    I want to try replacing the crown wheel and pinion, but I am not
    sure what other models ran the same diff centres as the VR-VS commos
    (obviously with the IRS rear end).
    Does anyone know a good, reasonably priced diff shop near Gladesville??
    Cheers,
    Nick
  2. immortality
    Sth Auck, NZ
    if the whine increases with speed but it's a constant whine it's most likely the pinion bearings that are stuffed. if you can play a tune by applying and removing power then it's the crownwheel/pinion thats possibly worn.
    hopefully it's just bearings that need changing. the gear sets in the BW78 seem to handle a lota off abuse reasonably well
