knowledge_is_power
Quest for Cognition
- Oct 15, 2004
- 288
- 7
- 0
- Location
- Nth Brisbane
- VT SII V6 A4
If you do a little search about the VY V6 you will see that they changed servicing intervals from the standard 10000km’s to 15000km's. This was done mainly because that’s what the opposition did. They changed the type of cam bearings and couple of little things including an increase in the oil capacity from 5L to 5.6L. This increase was achieved by the slightest increase in sump volume but also a dipstick with the full mark moved. If you compare a dipstick from a VS, VT, VX against a VY you will see that the VY full mark is higher on the stick. Meaning that the physical oil level can be higher in the Ecotech for VS, VT, VX, models then the full mark on their respective dipsticks. The total extra amount of oil if you where to use a VY dipstick would only be around 200ml.
Boiled down in a short answer you can put 5L of oil in at an oil change without a drama.
