Panic over...
Went to check front offside wheel bearing and 3, yes THREE nuts were finger tight, and one was 1/4 way down the thread...
OK the fix cost nothing but *I* did the nuts up when I swapped out the wheels. Would've done the proper tightening sequence too and a pinch with a long bar after tightening with a 4 way too.
Hmmmm.... not sure I can even blame my driving style either....
I tighten with a brace and then with a long arm thingy with a socket on. Trust me they're tight but then I remember...I always make sure I hear the creak when tightening the wheel nuts with a wheel brace....
Too tight can cause problems as well…I tighten with a brace and then with a long arm thingy with a socket on. Trust me they're tight but then I remember...
Too tight can be put right... too loose is no use...
So just buy a quality torque wrench and torque to spec you won’t have issues.
I actually chuckle when I read things like this....In all my years fitting, I have never ever seen a torque wrench in the boot of a car.....
Obviously you haven’t seen in the back of my car, or in the glovebox where the plastic lined socket is kept!
