My new VS HSV Maloo
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by vshsv97, Nov 23, 2006.
  1. vshsv97
    vshsv97 New Member
    VS HSV Maloo UTE
    Hi,
    i just have a general question which may seem very basic but i still have no idea, the ute is still fitted with the standard tape deck and i can't figure out how to get it out, my boyfriend has tried but hey he doesn't know that much and i don't want him wrecking my ute , so if anyone knows it would be greatly appreciated:)
  2. holden007
    holden007 VRII
    Subaru Liberty
    I reckon if your not very keen, spend $80 and get it fitted professionally, atleast if extra wiring is need the technican will provide it.
  3. POVRTY
    POVRTY building 5L VB TH 400
    taree nsw
    Wm L98 caprice
    u guys are up nice and early!
    pull the ash tray out and cig lighter and remove the plastic cover from the shifter. its easy just pull it up from the hand brake end. There will be 3 screws at the bottom of the suround undo and rip it out. the plug 4 the imobiliser light is on the back of the sterio suround. take out the glove box there is a slide pin that slides out on the right hand side of the inner glove box, its black just lever with a flat head screw driver carfully.
    use your commy key to undo the clips above the foot pedals, under the steering wheel there is a slide pin the same as the glove box on the drivers side when you undo these clips. pull the larger plastic suround out and with a small amount of work from there it should be a clear shot from there.
    let me know if i missed anything out and how you guys went, and welcome to just commys!
  4. Charg'd
    Charg'd New Member
    in a ford
    ford
    if you dont know what your doin, id recomend gettin it done proffesionally, or maybe on of the jc members could help, what state are you in?
  5. 97 SEN
    97 SEN New Member
    VS HSV SENATOR
    That is spot on for a vs sedan, but may not be right for the maloo ute.
    My senator is differrent in that the entire top of the centre console is one piece. you have to pull out the plugs that are in the lift up section of the centre consol then the entire top can be moved out the way with a bit of stuffing around, the the rest is as per above.
    if its like a standard ute with a bench seat and colum shift there is just a plastic skirt that screws in around the bottom.
  6. POVRTY
    taree nsw
    Wm L98 caprice
    no worries i just assumed they were the same.
  7. vshsv97
    vshsv97 New Member
    VS HSV Maloo UTE
    thanks very much for your help, I think i'll go for the professionally done way... I don't want to destroy my new toy just yet...:yeah:
  8. sganro
    sganro i speak before i think
    NQ
    yet another VS
    there's a very decent guide in the car audio section (thats if you dont end up paying for a pro job)
