My Opel Rekord E2 Caravan @ Opel Commodore C Voyage (RUSSIA)
CJey
Russia, Pskov region, Velikie Luki citi
Opel Rekord E2 Caravan @ Commodore C Voyage
Here to you slightly photos that wouldn't miss))) While I go by winter wheels in front, I wait new bushes in a front suspension, with wide wheels and big ET of a tire whistle on asphalt))))))
And here such tires today I bought - Hankook Ventus R-S3 Z222, all 205/55 because rims all 8J width
ajvx01
North east Adelaide
308 vc
Front spoiler suits nicely.
Kadett-Rekord
45
Dortmund , Germany
Rekord-E1 CarAVan / 2 + 4 Door Sedan
CJey
Thanks for the links)
I have all the wiring installed by Senator B, respectively, joined the dashboard without redoing wiring.
But I have a manual for connection by the LCD instead of the usual dashboard for Senator B and Omega A. Its enough, that would connect to the Record E / Senator A / Monza. Give your e-mail - I will send.
Rear brakes (But everything is in Russian, although parse through translator no problem):
For Commodores (300/284/280/262mm)
For Rekordes (240/264mm)
CJey
Redid the exhaust, because was not all too well, hung low and there was no muffler :)
That's what eventually happened
All autumn I was carrying parts and worked for Opel, repairing your Daihatsu until after the accident
Set fog lights, acquired earlier
Looking something like my every morning before you go to work - wet and nasty
Starting to be cold and that would not risk it, I put the winter wheels with studded tires (with our climate studded tires on the rear wheel drive cars really helps in the winter)
Been wanting to do - stick club stickers)))
Long concerned with the question of yellow lamps , and in search of samples of different options here what result I have come :)
Lamp H4 took in two versions - one Toyota 90981-13016 and the second Koito 0456Y, both were absolutely identical Philips 12342/86 (they're in sale there as TRW LLB 476, Mitsubishi MS 820963, Nissan B671K-C9906, 26719 -C9908, 26719 -C9922). In fact it is a standard bulb , which is set yellow cap , but unlike caps separately sold this cover fully the lamp bulb , also found in Koito yellow lamp 35W 4519Y, which looks exactly like P21W, this fog lights (Included were taiwan 35W, white , burned very quickly)
It is winter now in full swing, outdoor -15 degrees Celsius))
Adayer sportif commodore coupe
Hello do you know about 2 door commodores in australia called adayer sportif..
