The right way is referring to left and right, most springs are marked left and right, but I don't think the rears of a Commodore are, just the fronts.
Could be in the front springs too, a slight drop on a front spring can make the rear look down on one side.
Another thing to do that most people don't is to loosen all the control arm bolts to let the rubber bushes settle. When you lower the car, the bush is set for the original height, so once it's lowered, the bush twists. Most of the time it isn't really an issue, but it can make the car sit uneven. Not usually 1.5cm though.
