VTS5
TechJunkie
- Jul 26, 2005
- 1,373
- 300
- 83
- Location
- Sth.East\Melb
- VE OMEGA 3.6L Dual Fuel
Just replace the factory chains at 260.245klms.
Always use full synthetic oil and change it every 6K.
Altering between Nulon Full Synthetic and Shell Full Synthetic,replacing the filter every second change..that's a good run, I'm at 200k now still original chains 12/09 berlina dual fuel.
What oil you using?
After you clean it as good as you can I'd suggest running some cheap oil, get it damn hot and dump it straight away or you run the risk of all the crap that is washed down blocking the pickup and killing your bearings more than they already are. May have to do a couple of flush and dumps and probably drop the sump and clean the pickup again for good measure.
looking a lot better. Are you able to get the cams and heads any better or is that as good as it is gonna get?
