My two 5 litres- SS and Calais
304Calais
Here are my two fiveys, 91 Alaska white S2 VN SS, and an 89 Calais
SS has- stock motor except for twin-2.5inch exhaust, dumped at the diff
Built auto with 4200rpm converter and 4.11 minispooled diff
Calais has 180kw hsv enhanced motor, 3000rpm Hi-Stall and 3.08 minispool
304Calais
They look the good mate. Got any plans for them appart from laying down some nice elevensies in the ss? Lol
Donuts, lots of donuts... In a legal setting of course haha
Well I'm debating whether to go nuts on the SS and build te Calais as a cruiser for the missus, or returning the SS to stock and going nuts on the Calais.
In the mean time for the SS
I need to get some tubular upper rear control arms; I can banana a brand new OEM set in a month because of the minispool and boxed lower trailing arms. An adjustable panhard rod will help eliminate the rest of the axle tramp.
Then I want to bolt on a set of drag radials and see what she can run on the stock motor.
WazzaVN
Wazza VN
VZ 6ltr ute, VP Calais and HJ Prem
Well the ss should retain more value stock. So maybe the Calais should be the burnout machine. But then again you don't want the ss as a daily and put all the K's on it. So it's a bit of a tough one. The ss does already have the stally and 4.11s too I guess.
white vn ss
35
vn ss
That ss is pretty damn clean. Would go real hard with that driveline.
You should join the vn ss club.
Alloytec
Mandurah WA
LS1 VT SS
Hows does the 5lt go with a 4,200rpm stall ? Sounds a bit over kill for a stock 304 to me
