My VE II SSV Redline Sportwagon
Discussion in 'VE - WM' started by Treeman574, Jul 31, 2018.
  1. Treeman574
    Treeman574 New Member
    Gold Coast
    VE S2 SSV Redline Wagon
    Been on the site for a while now so I figure it's about time I made one of these. Here's my 2010 VE II SSV Redline Sportwagon. Still a long way from finished but it's blast on the road and track. More photos to come.
    Engine and Transmission:
    • 1 7/8 4-1 Ceramic Coated Hurricane Headers
    • Stainless 3" Manta Catback with Centre Muffler (Cheers NAAF!)
    • OTR
    • Rip shifter
    Power: 270rwkw (Hi-Torque Performance Gold Coast)
    Suspension:
    • MCA Street Performance Coilovers
    • 10kg F/R Springs
    Brakes:
    • Brembo 4 piston calipers, factory front and CTSV rear
    • DBA 4000 rotors, T3 front
    • Bremtec Evolve pads
    • Braided lines
    Wheels and Tyres:
    • 20x10" Koya SF07 in Gloss GTR Grey
    • Offsets +35mm front, +40mm rear
    • Michelin PS4S 275/30r20 all round
    • All guards rolled (Precision Guard Rolling)
    Coming soon... eventually... maybe...
    • Lower
    • Diff gears
    • Cam
    • Clutch (if needed)
    • Interior gauges
    • Exterior chrome wrapped black/grey
    • VFII HSV taillights
    • Number plate
    Would like to go a bit lower but I'm occasionally scraping on the work driveway at this height. Need to look at re-fitting the headers/cats better if possible. Either that or get some air cups for the coilovers.
    notStock, Zehq, VS 5.0 and 1 other person like this.
  2. VS 5.0
    Pics don't work :(
  3. MrBags
    MrBags Active Member
    VE SSV Z SERIES
    Nice car mate, good stuff.
  4. VS 5.0
    I can see the pics now.
    Nice car.....esp with those rims.
  5. arronm
    arronm Active Member
    FPV F6 VF Redline WGN
  6. Treeman574
    Gold Coast
    Got some nice shots from the last Queensland Raceway track day. Best time was a 1:03.7 on the sprint circuit. Was able to keep up with quite a few cars including an LS1 BMW and a VF GTS.
    Lots of body roll even with stiffened coilover damping so I'm getting some superpro sway bars for next time.
    Damaged the cat flange due to exhaust hanging too low. If the repair weld gives me some more clearance I might try lowering the front again. Would be nice if it looked like that all the time, not just under heavy braking...
    40507999_1824733620973836_9135598367206801408_o.jpg 40552155_1824732744307257_5242718689618296832_o.jpg 40621624_1824733150973883_7394278424790958080_o.jpg
    notStock and VS 5.0 like this.
  7. notStock
    notStock evolving
    Northern Beaches
    MY09 VE SS M6
    I'd definitely get the sway bars in, I did control + caster arms, front and rear sway bars and adjustable links, all superpro, you'll straight away feel the difference.
  8. Treeman574
    Gold Coast
    Yep you're definitely right! Got superpro sway bars and bushings. Amazing difference on track and nicer around town too.
    It feels like there's a bit less overall grip but it's so much more progressive. Before I was worried about suddenly losing traction but now I can comfortably push it right to the limit on every corner. Easier to drift too :D
    Finally dropped the front by 20mm to help even out the height. Now just about touching speed bumps with the cats and no room left between tyre and spring seat. Happy with the looks but might have to raise it a touch for more camber on the track every now and then.
    More photos too! 54516117_1566532180158545_1007087788446711808_o.jpg 53843106_1566532950158468_308737625219399680_o.jpg Untitled2.png Untitled4.png
  9. Treeman574
    Gold Coast
    Figure it's finally time for a cam. Leaning towards something like 224/230 114 LSA, but could go for something more extreme like 233/233 113 LSA. Any thoughts?
  10. 3_putt
    3_putt Member
    S.A
    VE SS ute
    Mint wagon mate, funny how you put on bigger sway bars with the MCA coilovers when they recommend keeping the standard ones in, even shockworks recommended standard. Was told by both that it’ll be too much.
    As for the cam I’ve got a kelford one in mine, highly recommend them super helpful guys for kiwis :p. Yours daily or weekender?
  11. Treeman574
    Gold Coast
    Cheers mate! Yeah I think one solution might have been to stiffen springs/damping as the stock body roll was just way too much for me. When I get a dedicated set of semi slicks I'll think about the setup again. Pretty sure wagons came with smaller sway bars stock though.
    Main problem is the 10s aren't quite the right offset. Can't add any more than 1.5 deg camber before tyre hits the spring seat...
    Yeah it's still my only car so has to survive stop start traffic and a stock diff ratio. Apparently the bigger of those two cams is a pain in small carparks, so Ieaning towards the smaller one.
