My vl has no spark
Vlberlina
Nz
88 vl 2.0
Hi all
Was driving my vl (only had it two days and it decided to crap out
It was missing at idle. Went on motorway and it decided to crap out
At first it was starting and as soon as I reved it it reved up then died.
Now it won't start at all
I've replaced the ignition module and still not starting. Any ideas
Vlberlina
Nz
88 vl 2.0
It appears to have no spark
LeighC
Northern Victoria
Omega V Commodore V6 Dual Fuel
Do you have 12 volts to the pink wire at the coil? with the key on
do you have 12 volts at the orange wire at the crank angle sensor? with the key on
does the fuel pump fire up when you first turn the key on?
Vlberlina
Nz
88 vl 2.0
I defo have 12v at the coil il try the rest u said and get back 2u
Vlberlina
Nz
88 vl 2.0
It's getting 12 volts to the coil and when I unplug the cas wires and touch the orange wire it's getting 12v
