Righto so im nearly settled after much moving etc and sorting my net out. been using my Mobile as a tethered bluetooth modem to get me by.
About a month back i took the L to a mates Exhaust shop and used a hoist for half the day. as i noticed an oil leak which was dropping off from my bellhousing. i immediately knew this was
the rear main was shot.. Hoping for just some loose Sump bolts or damaged sump gasket, sadly it wasn't.
So Gearbox out (trans oil was a little burnt oops) flywheel off and this is what i was confronted with
So out with the old and in with the new
Then while i was at it. Dumped the engine oil/filter, new input and output shaft seals on the box then bolted her back in. also ditched the old trans filter and installed a new one as well as tightened the front and rear bands.
Replaced fluids and away i go. Box is a lot more happy and i have no oil leak.Wooommmpppaaaaa
Stupid me i should have done the tail-shaft Uni's and center bearing as well but i did not think that far ahead from the other things i was doing.
Cheers Guys...
Nate
