Hey guys, been a while since i've made an update so here goes.
Had a few problems with it lately first the 02 sensor stuffed up. Also had e few random break downs then the car wouldn't start back up for 5 min. Then i was having trouble with it back fireing under load so i changed the plugs and leads but no cigar, turned out to be a blocked fuel filter and dodgy pump, so friday night i cleaned out the tank and put a walbro hi-flow fuel pump.
Then on saturday i made up some new brackets for the supercharger and bolted it all up and put on my 70 mm throttle body. Restet the computer and had her idling sweet for 2 minutes, was about to take her for a spin but as i was packin away a few tools i just started to cough and sputter and the revs were going up and down then it just stalled. It hasn't started back up since. Did a few checks and i'm guessing it the CAS, cos i'm getting no spark at all, and i hear that when a CAS is on the way out you'll get that random stalling problem, so currently my car is sitting at the mechics waiting to get fixed tommorow.
Got a 2 bar map sensor and rising rate fuel pressure reg $300 all up delivered to my door.
Now i've gotta sort out where to get a tune, sort out what injectors i need and save for the pulley then i'll be set till christmas time.
The car is also looking very poor ATM after a few carpark incidents, none of which were my fault. One guy reversed out of his space straight into the drivers door, left a small dent and a few scratches and some paint.
The other one i have no clue what happened but my car was parked for about 4 hours in the city, then when i was leavin as i turned the wheel left i heard a BAD scrubbing noise, so i jumped out to see what was up and the bottom of the left guard right near the door was all bent in.
I've straightened out the dent on the left gaurd so it won't scrub and i'll get it fixed when she goes in to have the drivers door done, just waiting on the other dudes insurance to pull their finhers put of their asses.
Also did a few g-tech runs the other night and ran 0-60mph 7.59 with wheel spin and light take off, all the other runs were between 7.9-8.1.
Traction was a major issue, i had the 17's on the back with thrashed rubbers on them and i wasn't able to give more than 3/4 throttle till i was over about 30km'h. This was with only extractors, 2 1/2 inch cat back, 3.7 diff gears and spool. Boot had 12" sub 2 amps, skateboard, orange gun, spare wheel, standard jack, and a trolley jack(about 10kg) and the back seat had a small tool box, overalls and boots, welding shield and the supercharger on the passger floor.
EDIT: also forgot to add that i now have VT front brakes on her and now she pulls up awesome, next i'm gonna add some slotted rotors and looking into chaning the master cylinder or something but that wont be for a while.
