[NSW] My vs commie
Discussion in 'General' started by Shaun Anthony Livermore, Sep 25, 2018.
  1. Shaun Anthony Livermore
    Shaun Anthony Livermore New Member
    Maitland
    1995 vs holden Commodore executive
    Hi all i recently done a v6 engine swap on my 95 Commodore executive, with a new battery and new starter motor. The motor however will not crank fast enough to fire. Any and all advice would be greatly appreciated
  2. Nut Kracker
    Nut Kracker Donating Member
    Echuca Vic.
    VT SS 304ci (195i)
    What size battery did you put in?
    Maybe not enough cold cranking amps.
  3. Shaun Anthony Livermore
    Maitland
    Hi i put in a battery with 640 cold cranks which i thpught wouldve done the trick but still the same issue still cranks but not nearly enough for it to fire
  4. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    Sounds like a faulty starter motor or possibly cables.
  5. Shaun Anthony Livermore
    Maitland
    I tested the voltage on the new starter motor once hooked up and it looked good but still not enough to crank fast enough to start, the weitd thing is everything tested ok on the voltage metre
  6. losh1971
    North Tas
    VR Ute V6
    Try load testing the battery. If that checks out the SM is probably on its way out. I replaced my starter because it was worn out and found the brand new one whips it over way faster.
  7. losh1971
    North Tas
    VR Ute V6
    You could try some areostart to get it running and see if it comes good after that.
  8. Shaun Anthony Livermore
    Maitland
    I used start ya basterd but still nothing
  9. losh1971
    North Tas
    VR Ute V6
    Turn your lights on, get someone to crank the engine and test the voltage in the battery at the same time. Report back what the volts are under load.
  10. vr304
    vr304 Well-Known Member
    Auckland, New Zealand
    2007 ssv manual
    Possibly an issue with an earth? Did u recconect all of the earths properly when you swapped the engine over? Also was your engine swap like for like? (Ie vs Ecotec for vs Ecotec)
