My VT commodore won't start
LaniJane
Qld
VT Commodore 2000 wagon
Hi my car recently run out of rego and has sat in my driveway for one month. I have never had a problem starting at ever and now it won't start. The battery died and was ruined so I bought a new battery worth $200. It still won't start. I think that the key or the immobiliser might have something to do with it. The buttons on the key are broken would that affected it? it's never affected it before. A few people say they have bought new keys and it's done nothing so I don't want to waste your money if it's not the key. Is there a way to disable the immobilizer? Do I need to reset the computer because I've put a new battery in. When I turn it over it wants to go, it's turning over but it won't actually fully turn on.
lout
60
Langwarrin Victoria
is the red mode led going out when you try to start
ant797
bunbury
vy s
Try using start you bastard I don't think it would turn over if the immobiliser is the issue ..so you proberly have fuel issues check fuel pump relay fuel pump etc
ant797
bunbury
vy s
You might of taken out the fuel pump relay for extra security and forgotten about it even
Forcedvp
VT HSV XU8, FORD TERRORIST
Do you hear fuel pump priming when you turn the reds on?
losh1971
North Tas
VE Series I SS Ute
I read this a lot. Funny thing is you can't always hear the pump prime. Some pumps are really quiet.
BlackVXGTS
Melbourne, SE
Have you tried paying the rego to see if that solves the problem (LOL)?
Forcedvp
Sometimes you can mistake the sound of the injectors initialising for fuel pump noise. Only way to know,(if you haven't done this already) is to get underneath car where fuel tank is and get someone to turn the reds on. You should definitely hear pump prime for 2+seconds
losh1971
North Tas
VE Series I SS Ute
I can't hear my pump prime but I used to be able to. I'd like to hear it so I know when to crank in sub 0 temps.
