VFSV6FORME
- Mar 9, 2016
- 2,603
- 1,272
- 113
- Age
- 74
- Location
- Brisbane
- WN Caprice V 6.0L, VE Anniversity V6 Series 1
The Caprce V was serviced at Sunco Holden in Maroochydore for the first 3 years of its life then after that when the people moved it was serviced a typical mechanic and repair shop at Yandina QLD. Have a pretty report on the service for the remainder of years up to Dec 2019, In the Report they have check this and check that, tick, tick, tick, tick, yes, yes, yes, NO, NO, No its look good but do they do it, Hummmm dont trust anyone. Only 2 days ago I took the Caprice V to have a 4 wheel Wheel Alignment and the report look Professional. I had BEFORE and AFTER Front negative camber (A EXAMPLE ONLY) BEFORE was -0.25MM and AFTER it was -0.28MM Different L and R. WOW there new Machine its very good, well the report looks good but they do FUc.K all.where was this thing serviced? Mine was done at GM dealers only and had up to date maps/mylink when i bought it. Can't be that hard.
I asked them "CAN I HAVE A LOOK WHEN YOU ARE FINISHED UNDER THE CAR AS I BOUGHT THIS CAR 6 DAYS AGO, I want to see if there is other issue" Now they replied Yes I will get a Technician to take you to your car and you can have a look under. Now on the report they adjusted the Front Camber but upon inspection I found the two front struts, those two large bolts + the adjuster not touch, never touched since the car was made. I made a Comment about this as those two large bolts has never been touched + the adjuster is the same, They comment,,, Well your car did not need to be adjusted,, I replied,,, why did you lie or the report sheet and I stormed out of the place,,, this is the shi.t we all have to put up with.
