Mystery Power steering leak
ab56452001
69
vn vacationer auto v6 sedan
Hi all , moved my 07 Auto v6 out of the driveway yesterday morn , and noticed a big puddle on the ground under front crossmember , wiped it all up and checked reservoir , all ok . This morning drove car around the block , came back , nothing no leak and steering fine ! . Just wondering maybe a relief valve got stuck and it piddled out ? , anybody got any ideas, cheers.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Tighten the clamps on the return line, they can weep over time if not tight enough.
ab56452001
69
Thanks for reply . Ill put on ramps tomorrow and tighten if needed . Weird thing is .drove around all day today and nothing ! . cheers
whats up
Australia
VL Calais
Hows the fluid bottle?
Has any been used/leaked?
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
Did you check your tranny fluid level/connection's /hose's?
ab56452001
69
Thanks for the replies , will get underneath today and check , didn't think of Tranny filler connection , but all levels show ok , if anything PS Resevoir needs a smidgeon , cheers.
ab56452001
69
Hi all . Just had a bo peek under car . Took a rag and torch with . Nothing dead dry ! . Didnt need the rag . Well bugger me ! . cheers .
whats up
Australia
VL Calais
What R U chasing here,a trans leak or a PS leak or both?Title mentions PS.
Cheers.
ab56452001
69
Originally I reckon it was a PS leak , fluid looked a bit to clean for Trans , any how , mystery still unsolved but not leaking now !
