That is where the sat nav wire is installed.
The airbag is not behind it. If you are concerned, disconnect the battery negative terminal. Pull the airbag fuse.
To remove the trim, pop off the cover that says airbag. Then undo the screw and the trim unclips with some effort. You might have to remove the side trim first. Can’t recall.
Hi all i bought a ve sv6 sportswagon acouple of months ago and noticed on the left had side of pillar along windscreen there's a wire tucked along the side. It doesn't look stock would anyone know what it could be?
