N/A beast
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Voodoovx, Apr 10, 2012.
  1. Voodoovx
    Voodoovx New Member
    Wa
    Vx ss
    Hey guys, I'm doing a naturally aspirated vx project and there are a few things I have been wondering such as,
    Is it worth going to a bigger set of injectors (40 poundish) for a 5.7l with just the usual mods exhaust, cam, cai, bigger throttle body, roller lifters, rockers and dual valve springs? And same question goes for an upgraded intank fuel pump?
    Also after market intake manifolds (I already have ls6 Manifold) and larger diff gears do they make all the difference?
    Cheers guys any input is appreciated
  2. Munz
    Munz Right Foot Action
    Brisbane NTH
    VZ Calais LS1 / VL RB30e daily
    won't need injectors or fuel pump with cam only, keep your intake manifold it flows well
    Diff gears will help get you moving if your cam is on the large side
    And do you realise heads have to come off to replace lifters? should give them a port and get them milled while their off!
