NA VL Running Rough Poor Spark
timboslice
19
NSW
Vl Exec
VL Exec NA running rough. Barely starts, idle speed up and down at random. Only getting a yellow spark. Heard one or two ticks/small bangs on drive back to mechanics.
Have replaced the following in the past 6 months
Spark plugs and Leads
o2 sensor
coolant temp sensor
dizzy
crank angle sensor
airflow meter
Mechanics have checked the ECU and it has no codes on it.
Thoughts?
H
harrop.senator
Guest
Chopper wheels not accidentally upside down when you replaced the cas is it?
Could be a harness or ecu issues. The harnesses are very old a friend after trying to repair all the usual stuff converted his to run rb25 cas iacv and other things wit an rb25 modified harness as e was that over misfiring issues. Theirs a lot of different things that are common to cause them on the 30 try and find and auto Sparky who is well known to rb30s.
Lacksballs
www.youtube.com
VK Group C Replica, 1995 VR Sedan
Check fuel pressure & flow rate.. Also look for vacuum leaks as starting points.
Love 4 cars
30
Vr stato
Could be completely wrong but maybe a gasket leak or an issue with the tappets or roller rockers like bearings etc making it misfire.. Had a skyline do this and one of my mates had same sought of issue with his vl.. He ignored though n ended up bending conrods the clown... Sounded like a supercharger winding trying to get it home from the highway haha
