[VIC] Nackerz Shed Cleanout....
Nackerz
Rollin
2 n/a vl's 1 twin turbo vl vn ss vy sv8
Hey guys,
Having a bit of a cleanout.....
DELIVERY/PICK UP INFORMATION: Pickup, can frieght at your expense
PAYMENT OPTIONS: COD, Direct Deposit, Funds Transfer
CONTACT DETAILS: PM, Post or Email at [email protected]
ITEM: N/A VL Auto Gearbox
CONDITION: Used, In excellent condition with only 200 odd thousand K's
PRICE: $250 NOW $200
OTHER INFO:
I have a N/A VL auto gearbox for sale. Came out of a running car, infact it's still in the car. Will be removed when sold or in the next couple of days. Keeping the cross member
Has 200 odd thousand K's on it. Shifted well and smoothly.
Auto
Torque Convertor
Flywheel and plate with flywheel bolts
Tailshaft
Trans Lines to radiator
PICTURES: Yes, will get more when I remove the gearbox
ITEM: N/A VL 25 spline drum brake sedan Diff
PRICE: $150 NOW $100
OTHER INFO:
No Noises and in good condition. Still in car
Pics: Not as yet
ITEM: VL Complete Cruise Control Setup
PRICE: $120 NOW $100
OTHER INFO:
Not sure if it's a factory cruise control, or an option as it was on a SL/Executive
Will get photo's when I pull the gearbox out as it has a wire running to it...
Complete with:
Unit
Cable to throttle
All wires
Purple Box where the wires come out of
Switch for it
And anything else that goes with it...
Pics: Yeah a couple. Will get more though when I remove the gearbox as there is a wire still attached. Couple of pics before I removed the motor.
Item:
Lumpy camshaft. This suits 253, 308 or 304 with carby.
It is a Hydraulic camshaft and here are the specs on it:
Application and Basic RPM
HYDRAULIC - Fair idle with lope, good mid range
- upper RPM horsepower and torque. Good street
and strip performance when used with correct
intake, exhaust and gearing.
BASIC RPM 2200-5400
Cam Use
Street/Strip
Deg. Dur.
@ .050”
Cam Lift
Int.
Exh.
224
224
Deg.
Adv.
Dur.
Int.
Exh.
290
290
Deg. Lobe
Separation
110
Running
Clearance
-Hot-
Int.
Exh.
.000
.000
Gross
Valve
Lift
Int.
Exh.
.496
.496
The cam is used, However it is in good condition
Price: $100 NOW $80
Pic:
Item:
308 STD size Flat top pistons with rods
Used but in good condition
Will post at your expense
Price: $150 NOW $130
Pics:
Item:
308 Standard Crank shaft. Removed to make way for the 355 stroker crank.
Pickup, will freight at your cost
Price: $100 NOW $50
Sorry no pics of this as yet.
ITEM: VL V8 4 Barrel Intake Manifold
PRICE: $70 NOW $50
OTHER INFO:
Good condition, Very Little Corrosion
Pics:
ITEM: VL V8 Extractors
CONDITION: Used
PRICE: $100 NOW $90
OTHER INFO:
Good condition, Suit early style heads
Pics:
ITEM: Holley 650 Double Pumper Carby
PRICE: $200 NOW $180
OTHER INFO:
Needs couple of things, Accelerator lingage and bolt in the top see pics
Pics:
ITEM: Torque convertor
PRICE: $80 NOW $50
OTHER INFO:
came of an A8 vlt motor I brought. Someone has written windsor on it????
Pics:
Think thats all for now.....Will update as I go...
Cheers Nackerz
Nackerz
Rollin
Ok guys, Here are some more pics of the gearbox, now removed...also comes with the cross member now as i dont need it..
Also there is more of the cruise control setup~ Will get more photo's of it all together etc... Cheers
Cruise Control
Gearbox
Hoska91
Formerly 75HJPREM
Getz Lyfe & E34 Project
hey mate any idea what brand the flat tops are ?
