need a how to on putting in an lsd
Scrusy
30
Nambucca Heads
VL wagon
Hey fellas. I got myself a 25spline lsd not long ago. Just wanted to know if anyone had a pictures or a step by step process with putting it. Its just the centre. Not the diff
K-BAGZ
De Plane! De Plane!
Far North QLD
VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
Jack vehicle up and support with jack stands. Isolate electrics.
Drain differential oil into suitable container.
Remove differential housing end cover.
Loosen crownwheel/bevel gear bolts. Note LH thread.
Remove wheels.
Disassemble drum brake assemblies. Place all parts into a small container so you don't loose anything. Take photos of assembly as well.
Remove axle shafts. Take note of LH and RH sides. Don't mix them up.
Mark the differential carrier caps LH and RH respectively (centre punch marks).
Loosen differential carrier cap bolts and remove caps, bolts and shims. Place in plastic bag correctly in relation to each side. Do not mix them up!
Carefully remove the differential carrier and bearing cups. Beware of pinch points and weight of object.
Count the splines of an axle shaft in relation to the splines on the new LSD centre.
Remove crownwheel off old centre and install onto new centre. Loctite must be used and bolts torqued to specification.
Installation is the reverse procedure.
Have you got a service manual for your VL? If not I can gain access to bolt specifications and procedures for you.
Scrusy
30
Nambucca Heads
VL wagon
Cheers mate. Very helpful! And yea thatd be sweet if u coukd give the torque specs please
K-BAGZ
De Plane! De Plane!
Far North QLD
First thing tomorrow on my to do list.
PM me if I forget.
K-BAGZ
De Plane! De Plane!
Far North QLD
Torque Specifications:
Differential housing cover plate - 30Nm. Use RTV silicone to seal if you don't have a gasket.
Crownwheel/Bevel gear (LH hand) - 145Nm with 277 Loctite or equivalent.
LSD carrier case - 45Nm with 277 Loctite or equivalent.
LSD carrier bearing caps - 60Nm with 277 Loctite or equivalent.
If you need anything else or pointers, just hit me up.
Good luck.
Scrusy
30
Nambucca Heads
VL wagon
Thanks will come handy. Preferred oil?
K-BAGZ
De Plane! De Plane!
Far North QLD
Penrite Pro Gear 80W-140 fully synthetic gear oil with Limslip additive. I'd buy two 2.5L bottles. If you can't purchase the Limslip additive, that's fine but I'd highly recommend it as well as numerous differential overhaul shops.
Viscosity: 80W-140
Base Oil:
Full Synthetic
Used in the following applications:
Hypoid & Limited Slip Differentials
Can be used where the following SAE viscosities are recommended:
SAE 140
75W-140
85W-140
Replaces SIN Gear 80
Pro Gear 80W-140 is a premium full synthetic, SAE 80W-140, API GL-5/GL-6/MT-1, heavy duty gear oil that uses a special combination of synthetic base oils which include PAO and Ester, with an advanced additive system to provide performance and protection under severe service.
It can also be used in applications requiring an SAE 85W-140, 75W-140 or SAE 140 gear oil.
Designed for use in differentials, both hypoid and limited slip, of competition vehicles and many makes of cars, light commercials, 4WDs and trucks.
Customer Benefits:
Ultimate protection
Race proven performance
Longer drain intervals
Superior protection against scoring & spalling wear
Compatibility with copper alloy components
Minimises chatter
Minimises inventory
Key Specifications:
API GL-5/API GL-6/MT-1
MIL-L-PRF-2105E
Ford M2C-190A
