Need advice on VE SS exhaust fix
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
It will probably make it louder, not sure on the quality of the note though, may end up raspy and drony though as the rear resonator is pretty small on X Force.
Nurb
Gold coast
Ve ssv wagon
I have a stock cam l76 wagon. Has pacemacker 4 into 1 00 cell cats. Twin 3 inch x force system that has been turned into a bitsa. Has magnaflow resonators that have replaced x force resenators, have j pipes on the rear with resonators. It sounds good high rpm and low rpm but is too dull and smooth around 1500-2500 rpm. Would replacing the x merge pipe with a h pipe make a better note?
You seem like the most informed on exhausts here so i thought id ask you. I want a deeper more chopped out note if that makes sense.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
That would be the ideal setup if it is "dull and smooth" between 1500-2500rpm. That's where you do most of your driving so you don't want it loud and drony around there. IMO, don't touch it.
To answer the X pipe question, it will change the note, make it more refined, possibly louder.
Nurb
Gold coast
Ve ssv wagon
I had a H pipe fitted where the x force x pipe was. Wow what a difference. Has a angry bark to it now really deep. Sounds awesome. Almost like a merc amg 63 or something.
