Alright thanks for the help mate I’ll have a look at thatSounds like the starter has died. They wear out but also have problems from oil inside on the Buick from leaking head gaskets. Being a VN it's probably just old and has worn out brushes.
Yeah definitely got plenty of charge in it. Sweet as I’ll give that a go soonYou could try bridging the starter with a screwdriver. I assume you have a fully charged battery?
Oh yeah I got a set of leads so I’ll just do that cheers mateBridging the starter solenoid with a big screwdriver will spark a bit, I'd wipe any oil away before I tried this. Also, if you have jump leads, you can connect the solenoid starter side directly to the battery to see if it spins.
Would a starter motor on the way out cause the car to run bad on 2 cylinders haha? Or the ignition switch
Yeah, all parts are brand new. That’s what I was hoping it was in the first place but didnt do much when I put them in.No. The starting issue could be ignition switch or more likely the starter.
The running rough issue is something else, I'm leaning towards a dead coil or the DFI module. Were the ones you fitted new or second hand?
