Gordon VZ ute
- Oct 28, 2020
- 7
- 0
- 1
- Age
- 58
- Location
- Malanda QLD
- VZ Ute commodore
Car was initially throwing PO160 code for rear post cat sensor bank 2 which has been repaired. (Turned out someone had butchered wiring when they were installing wiring for oil pressure gauge). But now that it is working it’s throwing 2 codes P2272 stuck lean & P2098 to much oxygen post cat. Anyone with ideas on how to fix would be much appreciated. Has stock manifold and cats but has 2.5 inch xforce system from cats back. Wanting to fit extractors and high flow cats then get fuel injectors cleaned or replaced and then retune car. Not sure if this will be enough to fix problem.
